Chicken gravy from stock cubes??
23 May 2009
Hants/Berks Border
This is kinda urgent (and also a n00b in this particular sub-forum) but getting off-the-shelf GF gravy is proving hard tonight and we were planning chicken pies for dinner
Do have some OXO Succulent Chicken stock pots - is it as simple as adding cornflour to it to thicken it?
Usually use sachets to make up 300ml so thats what quantity we're after
Thanks guys
Yeah, that'll work though you may want to add less water (or reduce the gravy a lot). I'd personally also caramelise some onions to stick in there with it and add a little garlic, maybe some herbs, etc. Just chicken stock cube gravy will be kind of bleh.
What FrenchTart said. depending on the stock pot it could be rather salty as well. You could try adding some cranberry sauce or jam in that case. Or get some wine in there.
It supposedly has garlic and thyme in it.
Can't have onions - make me sick :(
So just gently heat say 250ml water with stock cube and add cornflour??
Yeah but as bsoltan said, make sure to test how salty it is. If it's too salty just add a small amount of sweetness to it to help cover the saltiness. Don't worry, if you only add a little you won't be able to taste the sweetness - just will be able to taste less salt.
With cornflour you don't add it to the dish you should create a slurry first or it'll just clump up.
That being said if you're making chicken pies any decent recipe wouldn't need chicken gravy.
+1 gotta slurry cornflour first, one table spoon and enough water to turn it, add it in small amounts and stir, test, add a bit more. A little goes a long way. Make sure its not boiling too ferociously when you add the slurry, but bring it back to the boil before adding more - when its boiling that is as thick as it will get. Heat it through for at least 8-10 minutes before serving or you will taste the flour. Cornflour slurry reduces flavor, so you will likely need more seasoning, bearing in mind the saltiness of the stock cube as stated above. Finally, take it off the boil and add a knob of butter to bring back the shine.
