Hey,
Ive been given one of these cases. And have decided to hack it to bits!
Sorry for the poor pics only had my phone to hand at the time
well here it is
then this happend
Resulting in this
as i was experimenting
i sanded the side panel
now i want to keep the steel bare either plain like it is (if i can get a good enough finish) or brushed
the other side panel top and bottom plate will be the same and clear coated
i want to cut a full window and either mesh behind it (perforated steel or wire mesh)
also the front bezel feet handle and chassis will be painted the same colour suggestions?
what do you guys think any input or suggestions would be appreciated
this is my first case mod so bare with me
and were already on hold till later this week run out of sanding mats alltho i could cut the window
JK
well here it is
then this happend
Resulting in this
JK
really nice case. I would keep it black and get the metal frame inside powder coated black also, a side window could be a welcome addition....
Good luck with your mod...
