Chilly yet hot?
Caporegime
6 Dec 2005
Birmingham
According to Core Temp and Intel TAT my E6700 temp is at like 52 to 60 C idle. That a bit to hot me thinks, is it?
At LMAO at the System temp that SpeedFan says. -65C :cool: :cool:
What CPU cooler are you using, bear in mind TAT reads directly off the die I believe.
It does sound too hot.
Rob
Yes, that's quite worrying warm - not from a damage point of view - the CPU will shut down if it gets too hot, but it will almost certainly be throttling after running at 100% utilization for any period of time and therefore giving you poor performance.
w3bbo said:
Reseat your block?
Dont think ill need to do that now w3bbo.
By the way it only does that temp for like a split second. Took me 20 odd attemps to get it. Then it goes to the correct one.
