Looking at buying either a chimney balloon or one of the other draught excluder devices to plug the hole in our chimney flue in the lounge to stop it being draughty and losing heat.
Does anyone know if the balloons are a better purchase or if the fabric type are a better buy?
http://www.amazon.co.uk/Chimney-Bal...113144&sr=8-1&keywords=square+chimney+draught
http://www.amazon.co.uk/inch-Round-...113144&sr=8-3&keywords=square+chimney+draught
Gave the opening a quick measure and its about 10 x 10 inches square. Wasn't sure if the round fabric ones would be much cop. Anyone used either and able to offer any advice?
