Chip info for my OCZ Platinum
16 Dec 2005
Manchester
Okay I have been searching around t'internet for ages and I can't seem to find out what chips my OCZ Platinum 1GB sticks use! The part number is OCZ4001024ELPE.
Would like to know what chips are on there to help me get the most out of them when I OC my rig in a few days.
SiriusB
http://www.xtremesystems.org/forums/showthread.php?t=50010
PC3200 Gold EL GX XTC - Hynix D-5 or Infineon BE5\6 + Brainpower PCB
PC4000 Gold EL GX XTC - Samsung UCCC + Brainpower PCB
PC4000 Platinum EB - Infineon CE-6 + Brainpower PCB
PC3200 Platinum EL - Infineon BE-5 + Brainpower PCB
PC4000 Gold EL - Samsung UCCC + Brainpower PCB
PC4000 Platinum EL - Samsung UCCC + Brainpower PCB
PC3200 Performance - Infineon BE-5 + Brainpower PCB
PC3200 Value - Infineon CE-5 or BE-5 + Brainpower PCB
Get the ram and cpu overlcocked, run some mem test for a good hour with you case all sealed up.
Pop the ram out and very gently pop the IHS off, the heat will soften the thermal tape. You can then check the Ic's. To refit heat the IHS with a hairdryer then pop back on and pinch the ram along every Ic's to make it stick and check your ram is okay. Then carry on as per normal knowing what your ram really is.
Shame there aint no way or nothing like a cpuz for mem....haha Memz it could be called!
