The chipset fan on my DFI SLI-DR has started making a proper loud noise after months of being fine, is there anything quiet i can replace it with?? it's well annoying.
the problem is that it's right under the end PCB of my graphics card, so whatever cooling i use it cant be any bigger in height than the standard fan or it wont fit.
