chipset fan for socket 939 ?
23 Jan 2007
Glasgow
Hey guys
im looking for a chipset fan and the heatsink that would attach to a socket 939 board, I gave the fan and heatsink away when i stopped using it a couple of years ago, but now want to put it together as a spare pc, but got no idea if anything like this is available. any ideas?
cheers
edit.
found this, anyone know if they are any good for 939's?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-026-AK
Seems decent enough, its only a fiver so you might aswell give it a try really.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-AR
Cant really go wrong with that, dirt cheap and as far as i can remember it done the job very well on 939.
Be interesting how you would fit a CPU fan on a chipset fitting.
There's this one
http://www.overclockers.co.uk/showproduct.php?prodid=SY-007-ZA&groupid=701&catid=57&subcat=399
If you've got a Nforce board I'd probably try and use a air cooled chipset fan. Ideally the Thermalright HR-05 or Noctua NC-U6 Dual Heatpipe Northbridge Cooler
