Hi,
I've been refurbishing an old broken computer and managed to get it working again after replacing the hard drive, graphics card and reseating the cpu cooler with new thermal paste. However I'm running into one last problem whenever I start the PC up the BIOS gives me a warning saying the chipset fan isn't working, I assume this is the southbridge fan which indeed isn't working.
I've installed XP and run some temperature checks and all seems normal however is it safe to leave it running without the fan working? It's an Asus A8N-E Nforce motherboard
http://www.asus.com/products.aspx?modelmenu=1&model=455&l1=3&l2=15&l3=171
so is it safe leaving it like this? All temps are 40 degrees C or lower, or should I buy a new fan? And would this:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-026-AK
for example be able to replace it?
