Hi All can somebody clear something up for me please i,m confused about what is the newest chipset of these 2 the 975x or 965p ,i know that the 680sli &650sli are new ,just wanted to know about the other 2 thxs
975x is the newer chip set but uses the older southbridge.neither support sli but 975x is naitive crossfire and most major manufacturers have a bios to allow crossfire on the 965 chipset(only if it has two full size pcie slots ie p5b deluxe/wifi,gigabyte 965 dq6 etc)
in my opinion only,the 965p is the better chip set as it allows a higher over clock with the lower mhz chips ie e6300 and e6400 which i use.if you go higher a lot of people on here have found the 975x to be the better chipset.but as mentioned i use the lower mhz cpu's at the mo so have expierience only with the 965 in the shape of the p5b deluxe wifi on my other pc....eg_esi
