CHKDSK, Corruption and Consistency
23 Nov 2002
Near Bristol
Hello,
Here's an intro as I think it's pretty relevant, I'm sorry it's a bit on the long side, but I wanted to make sure everything was mentioned so please bare with me as I really do need some help with this. Especially from those who have experience with Hard Drive corruption and Windows CHKDSK problems. If you'd rather skip to the questions that I need help with then go to the end of this post, but for it all to make sense I’d recommend you at least scan the below info. Thanks in advance for those who can help.
Basically one of my systems (used by my sister) has had some semi serious problems for a good while now, every now and again it would get BSOD's on start-up and sometimes the Windows XP checker would pop up with the message "Drive C: needs to be checked for consistency". It would usually find a few problems, delete some corrupted files, recover a few and boot into Windows normally. Those problems and a few application/game errors were about it, no other major stability problems though.
So once first happened I of course suspected the Hard Drive cable first, tried another, didn't fix it, and scanned the hard drive several times with Western Digitals DOS based Diagnostic software, which it passed several times with no errors on both the quick and long scans. I did everything I could think of, memtest to check the Ram, Formatted and Reinstalled Windows but nothing seemed to sort it. Although I can't be certain I'm pretty sure that I even swapped out the hard drive in the end and that still didn't fix it, but my memory isn't what it used to be. Either way I assumed that the motherboard was faulty and planned a much needed upgrade replacing nearly everything with more trusted and powerful parts.
The problems were still happening but a few days ago I managed to get all the parts I needed and I therefore backed up her files on my main computer by transferring them over the network to a folder in the main C: directory. I then assembled the computer and nearly every part was changed Including Case, Power Supply, Processor, Motherboard, Graphics card etc. The only parts that were not changed were the Hard Drive, CD-Rom/Floppy Cables, Floppy Drive and the Ram. Even the hard drive cable was changed for something brand new, an Akasa cable that I use in all my other machines without any problems. Everything went fine, Windows installed great and I got all the drivers, Windows Updates installed. Installed some applications, games and the usual things she uses and everything looked great. I did a few stress tests, ATI Tool, 3DMark 05/06 and a game or two just to make sure everything was working fine and it was. The only slight glitch I had is hardly worth mentioning but I will for the sake of it, I used Riva tuner to lower the fan speed on the 6800 Ultra as it’s pretty loud and I think I went too low. The temp was only around 85c at load but ATI Tool still picked up some artifacts, either way I increased the fan speed and the problems went away. I then transferred back some of the backup's including e-mails, game saves and so fourth along with some file's that were backed up as well. After that the computer was shut down.
Now today I started it up but wasn't in the room when it did, I installed some drivers for printer and then rebooted. I watched the reboot process and to my horror the "Drive C: needs to be checked for consistency" message came up and it found a few problems as usual and started up. I checked the application logs in the Control Panel and found out that it had done that this morning as well, when I first started the computer up but this was the first time it happened. I then decided that I might as well run CHKDSK manually, so went to CMD, typed "CHKDSK C: /F /R", it needed to reboot and it ran it on start-up like the automatic test. Doing it this way however tests a few extra things so took longer, but it did find problems again as usual. I did this again and it found problems and the final time I did it, there were no problems.
So I thought great, however when I came back, expecting it to be sitting on the Windows Desktop there was the old "We apologise for the inconvenience, but Windows did not start successfully... etc". Giving you a 30 odd seconds to select from the 3 types of Safe Mode, Last Known Good Configuration or to Start Windows Normally. None of which work, no matter which one you select and if you press enter or let the time run out the screen goes black and the system reboots. Just my luck!
As you can well understand I'm not sure what to think, if it was just CHKDSK checking the drive for consistency after I transferred her backups then I would have course think that they were corrupted on the old system due to the motherboard, but as I can’t get into Windows I’m really lost as to what could have caused it. I've just completed two runs of Western Digitals Diagnostic software with No Errors. The Windows XP SP2 installation CD is fine, as I've used it before with no problems. I’ve also done a few passes of MemTest with no problems, although I guessed that it would be fine. So I'm not sure what to do, anyways here are my questions, some I think you'll already of guessed.
Question 1: Is it possible for a hard drive to be faulty and yet pass the manufacturers own diagnostic scanner? Anyone had any experience of this? Especially if the drive turned out to be what was causing the corruption.
Question 2: Could these backed up corrupt files be missed by the operating system of the system used to store them, if they were simply transferred to the hard drive in a folder. My thinking is that as they were not part of any sort of file system, the main computer that they were stored on didn't pick them up. Although I don't know much about this sort of thing and could be way off.
Question 3: Could a few corrupt files non-system files actually do what I last mentioned or was it CHKDSK deleting files that caused the problem? My guess would be the latter.
Question 4: If it was CHKDSK that was causing the problems, then surely that means there's something wrong, either hardware or driver wise. Any ideas considering the tests and results I’ve gotten.
Question 5: Is it possible a faulty CD-Rom cable could cause these problems? I’ve never had problems with it before but I guess it’s worth considering now.
I've heard that the nForce IDE SW driver causing problems, but seeing as the other motherboard was VIA, I can't see that explaining how both computers have the same problems.
I think it’s a bit pointless putting the full specification of both systems down as so much has changed between the two but the Hard Drive is a Western Digital WD800JD which is an 80 GB, SATA, 8 MB Cache, 7200 RPM drive of which I have 5 including this one, the other 4 are fine and this one is of course unknown. That being said however, the other 4 are run in pairs using Mirror Raid while this is the only one I have running on its own. The previous motherboard was an Asus A8V Deluxe, VIA chipset, AGP and 939 Socket. The current is an Asus A8N-E, NF4, PCI-E and again 939 Socket of which I have two more, both work perfectly. If anyone specification details then please let me know. As mentioned I have two other A8N-E systems, both work fine and one has very similar specifications.
Any other suggestions, experiences or theories would be greatly appreciated; I really do need to get this problem sorted as soon as possible.
Thanks for reading.
Regards,
Mark
My guess, given the steps you've taken would be the ram.
download and run memtest86 on it, as a fautly memory module can give file corruption and errors (if the ram is dodgy then the os can be saving files fine to the drive - but they could be corrupt before being written).
Hi,
Thanks for your reply.
As mentioned I used memtest when I had the first set of problems and it passed with no errors and I did also try it again yesterday, admittely it's not that easy to pick out from the mass of text. Either way here's my lastest update:
Right a quick update, in the end I left MemTest running and it did 7 passes with no errors. This morning I attempted to repair Windows so I booted from the Windows CD and hoped that I could do a repair install, however the previous installation was not recognized by the CD's setup wizard showing this screen...
After some research and checking out things I already knew I worked out a few things I could try from the Recovery Console.
After seeing that message for "fixmbr" I decided to try some other things before that.
(Excuse the blurring, but it's just about readable). I tried "fixboot" but even if the operation was successful it didn't sort the problem and the computer has the same symptoms as before.
"bootcfg /rebuild" this time, couldn't be completed due to a corrupt file system. Doesn't look good!
So I actually used "fixmbr" this time and although it appeared to work it didn't sort the problem. It does also mention the whole "non-standard or invalid master boot record" which also isn't a good sign.
Does anyone have any other suggestions to try before I write Zero's to the drive and reinstall Windows?
Update: I've wiped the drive using WD's Diagnostic tool using the Full version of "Write Zero's to Drive" and then reinstalled Windows. I installed all the same drivers, updates and the basic things like firewall and AV.
I was about to do a CHKDSK and spotted this in the Event Viewer under System:
Date: 09/09/2006
Time: 12:28:08
Type: Error
Source: Ntfs
Category: Disk
Event ID: 55
Description: The file system structure on the disk is corrupt and unusable. Please run the chkdsk utility on the volume C:.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Oh yes and on reboot it wasn't much of a suprise that CHKDSK wanted to check the drive for Consistancy.
I actually skipped the tests for consistancy to see what would happen, although I did run two manual CHKDSK runs using the /f /r modifiers which found problems. I have also installed HD Tune and Active Smart as you suggested Max Tractor, which among other things check the SMART data from the drive. It appears with the hard drive passing both WD’s test and being fine with regards to SMART data that I can rule out the hard drive as being faulty, although that of course doesn’t rule it out as being the problem. I've just tried a new CD-Rom cable but haven't got round to reinstalling Windows yet, however I'm pretty sure it won't make any difference and it appears I’ve gotten desperate. But I guess it’s good to rule things like this out, one less thing it could be!
Here's another update:
I decided to do something that to be honest I should have done sooner, take the hard drive out of the system and try it in another. So I did, formatted it using WD's Diagnostic Tools (Write Zero's To Drive - Full) and installed Windows, then straight away I ran CHKDSK and this came up:
Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
Cleaning up minor inconsistencies on the drive.
Cleaning up 18 unused index entries from index $SII of file 0x9.
Cleaning up 18 unused index entries from index $SDH of file 0x9.
Cleaning up 18 unused security descriptors.
CHKDSK is verifying file data (stage 4 of 5)...
Windows replaced bad clusters in file 9915
of name \WINDOWS\system32\dllcache\obrb0414.dll.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
78140128 KB total disk space.
3230944 KB in 9790 files.
2400 KB in 628 indexes.
0 KB in bad sectors.
78780 KB in use by the system.
65536 KB occupied by the log file.
74828004 KB available on disk.
4096 bytes in each allocation unit.
19535032 total allocation units on disk.
18707001 allocation units available on disk.
I then changed the cable for one used fine on other systems and got pretty much the same, although no mention of "bad clusters" this time, but I'm guessing that was just luck:
3231056 KB in 9796 files.
2404 KB in 628 indexes.
78824 KB in use by the system.
74827844 KB available on disk.
18706961 allocation units available on disk.
So of course there are only (in my mind) three things that could cause the problems on both systems:
1. The Hard Drive is indeed Faulty
2. The Hard Drive doesn't like the motherboard (same as the problem system), older firmware may have something to do with this.
3. The Windows Installation is slightly bad.
I went for the fact that the hard drive is faulty, simply because the Windows installation has been used before with no problems and even if it is slightly bad I'm not happy that it caused the failure of Windows on the problem system.
This was sealed by Western Digitals reply:
Well my main question is simply this, can a hard drive pass your DOS based Data Lifeguard Diagnostic software on both tests numerous times yet still be faulty? Yes. Although it passes out tests there is clearly some surface damage on the drive. The built in error correction is at work to repair the drive while it is being tested and used and therefore it passes tests, but Windows gives problems because sectors are being reallocated. You have done a lot of troubleshooting and all that is left is to exchange the drive. We are happy to swap the drive under warranty in this case.
I decided not to RMA it yet as I wanted to order another drive and make sure that it was indeed the Hard Drive at fault, I really do want to see the back of this problem for good.
The Hard Drive arrived today, it's a WD2500KS (SE16, 250GB), which will be used in my main pc, freeing up two WD800JD's for the problem system.
So I set it up, did the same test on the non-problem system as I had before. Installing Windows, doing the CHKDSK right away and this is what happened:
244187968 KB total disk space.
3230924 KB in 9790 files.
83876 KB in use by the system.
240870768 KB available on disk.
61046992 total allocation units on disk.
60217692 allocation units available on disk.
I was really wishing for this to be the end of it and for it to be a clean CHKDSK run, so I'm not quite sure what to think. These CHKDSK runs once Windows is installed are hardly the most definitive checks to see if the "Checking for Consistency" problems will occur. So it's possible that the installation CD is slightly damaged or that this is normal and happens on every installation. I'm going to try and get another installation CD, until then I'd be happy to hear some opinions and thoughts on this.
I am hoping that someone would be willing to do me a small favour. If you have a spare Hard Drive, or are going to reinstall Windows XP Pro SP2 anyways, could you run CHKDSK once you get into Windows, before anything else and post the results. Running it is easy. Go to Run, Type CMD, In the Command Prompt Window type "CHKDSK c: /f /r" and press enter. It should say that it cannot lock the drive and needs rebooting, press Y and Reboot. One thing to mention though, is that even if it appears there are no errors while running it it's best to check the logs as errors have appeared in there that were not present when the test was running. To see this go to the control panel, then Administrative Tools, Event View and then Application. You are looking for the latest entry of "WinLogon" which will give you a break down of the test, it will look very similar to what I've posted, if a bit longer.
If you've got to the end of all this, thanks for reading and I look forward to people’s thoughts and opinions.
The unused index entries are entirely normal. I'm not entirely sure why these appear sometimes, but I've seen this happen tons of times. Free space marked as allocated in the volume bitmap is also not the end of the world- Usually means that something hasn't deleted properly & is nothing to worry about.
-Leezer-
-Leezer-
Indeed, I'm starting to realise that and after trying another installation CD the same problems appeared:
Cleaning up 17 unused index entries from index $SII of file 0x9.
Cleaning up 17 unused index entries from index $SDH of file 0x9.
Cleaning up 17 unused security descriptors.
3273880 KB in 10088 files.
2484 KB in 641 indexes.
84196 KB in use by the system.
240827408 KB available on disk.
60206852 allocation units available on disk.
So like you say this is normal, although that being said I'd still be grateful for someone else with a Windows XP installation (even better if it's XP Pro SP2) to do what I'm doing, installing a fresh copy of Windows on a formatted drive and running CHKDSK to ensure that it is 100% normal for a new installation, details/instructions in my last post.
If it does turn out to be normal then I'm going to have to find another way of testing both this old drive and a new one. From what I see this will be installing Windows and waiting (god I hate waiting!) to see if the "Checking for consistency" message comes up again on it's own.
