chkdsk hell (or how do i stop it running)
23 Jan 2003
N.I.
i day or so ago i had a program crash tell me it had to run chkdsk, and since then ive been in chkdsk hell,
when i start the machine it run's chkdsk, fixes a error then reboots the machine. then runs chkdsk again. it keep doing this unless i "press a key" to stop chkdsk wheni first starts.
what i need to know is there some file i can edit to stop chkdsk running at all
Carter said:
start - run - and type...
chkdsk /X /F [driveletter here]:
example
chkdsk /X /F c:
chkdsk cannot run because the volume is in use by another process...would you like to schedule this volume to be checked the next time the system restarts?
y/n
y/n
Sorry about that, yes as TrUz says let it run at next bootup.
