Choice between ASUS PG348Q and Acer Predator X34A
24 Jun 2009
London
I've boiled it down to these two now. Looks like the Asus has wider colour gamut and uses 10-bit, although would be good to hear from anyone who knows whether there is a material difference.
I know some HDR monitors are coming out but am guessing this will be a while and none of them seem to be over 27". I'm keen for a display size > 27".
Thoughts, anyone?
Where did you see the Asus having 10-bit? They're the same panel, unless something drastic has changed??
No HDR G-Sync at this size for a good while yet, and when it arrives expect to re-mortgage to be able to afford it.
Says so here:
https://www.asus.com/uk/ROG-Republic-Of-Gamers/ROG-SWIFT-PG348Q/specifications/
Is this a fib? Perhaps it's 8-bit + FRC then?
If it's not a 10-bit then my options are:
https://www.overclockers.co.uk/acer...descreen-led-monitor-black-red-mo-097-ac.html
This is 8-bit + FRC
OR Dell's true 10-bit
https://www.overclockers.co.uk/dell...-led-4k-monitor-midnight-black-mo-085-de.html
Will lean towards the Dell.
Card I'll be using: Geforce Titan X (Pascal)
Those last two aren't curved or 21:9; not sure if that's vital for you or not.
