Choice Critique
24 Apr 2013
I'm hoping some experienced folks could cast their eyes over my intended watercooling setup, in particular the suitability of the pump for pushing water through the other components, listed in loop-order:
Pump - XSPC Dual-bay res/pump combo, 750lph
CPU block - Magicool MC-block copper rev2
1st Rad - Coolgate HD120
GPU Block - Watercool Heatkiller full-cover copper & stainless steel
2nd Rad - Coolgate HD240
Fittings - black nickel coated brass compression 10/8
My GPU is going to be 'somewhat' :cool: overclocked, nvidia 560GTX Ti
My CPU is moderately overclocked 4-core AMD FX, later upgrading to an 8-core.
My main point of concern is the pump, and it's ability to push water through two blocks and two rads, I have no idea of how it'll cope with that. I have enough space for a second pump mid-way through the loop if needs be (case is a Thermaltake Level 10 GT). I have a lot of experience with modified systems but new to watercooling (been using closed-loops & air cooling).
