Choice of 3 ram kits.
22 Mar 2006
Kent
Choice of 3 ram kits. Need your opinion.
Looking to upgrade my nasty poor timing cruical ram to something that will be a lot more overclockable. I have an AMD Duel core +4800 and MSI RD480 Neo board and so far im looking at the below kits. They all seem to be the same on paper but would be interested in getting everyones opinion on which would be best.
The FSB limit for my system seems to be around 240 and unless im not very mistaken i should be keeping the ram on a 1/1 divider so it wont be higher then this.
The kits im looking at are the PC3200, 2-3-2-5 kits.
OCZ Plat
G.skill ZX
Mushkin Blue Series.
Are there any other kits availble (with tight timings and higher then PC3200?) Which of these perform best for overclocking (read good things about all of them so far).
Thanks.
they are all good performers but i can personally vouch for the ZX kits. Got it and runs perfect, tight timings.
sometimes it's alottery if you can get PC3200 to run @ 240fsb , some kits run that easy - others don't
just bang it on a divider and keep the timings tight. no real performance hits for AMD's
