Choice of thermal paste
18 Nov 2007
Deepest Darkest Essex!!
Bit of a dilemma folks.
I'm about to do a build (part rebuild really) & I've gone to look for a tube of my trusty Artic Silver 5. Trouble is I cant find it! :mad: I've found 2 other thermal pastes & they are
Prolimatech thermal compound.
Zalman Thermal paste.
So which one do I use, as I cant be arsed to go out & get some more AS5 (I'd have a job finding any in my local shops period let alone today)
Want to get this build off the ground today.
Thanks.
Agree with Mr-White, just use whatever you have at hand, even if you do eventually get something like as5 the difference in temps will be pretty small. + you can get your rebuild up and running.
