Choice of two 7800X3D / 4090 systems
26 Jun 2023
UK
Hello,
First post seeking your advice. I have two builds for a high end gaming PC and I'd like your views on if one is notably superior to the other or whether there are particular drawbacks to either. They are both fundamentally the same (CPU and GPU) within c. £100 of each other.
The two are:
COMPONENTSYSTEM 1SYSTEM 2
MotherboardASUS TUF GAMING B650-PLUS WIFIAsus PRIME X670-P WIFI ATX AM5 Motherboard
ProcessorAMD Ryzen 7 7800X3D, 8C/16T, 4.2GHz – 5.0GHzAMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor
CPU Cooler3XS 240mm ARGB AIO Liquid CoolerCorsair iCUE H150i RGB ELITE 65.57 CFM Liquid CPU Cooler
Memory32GB (2x16GB) Corsair Vengeance RGB 5600MHz DDR5Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory
Graphics Card24GB NVIDIA GeForce RTX 4090 (unknown which particular model)Asus TUF GAMING OC GeForce RTX 4090 24 GB Video Card
Power SupplyCorsair RM850X - 80PLUS GOLDCorsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
System Drive2TB WD Blue SN570 NVMe M.2 SSDSolidigm P44 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Many thanks in advance for your help.
Alex
The second one is likely to be a better system, though the unspecified cooler and graphics card model makes it more awkward to tell.
On the face of it, option 2 has:
- A better cooler.
- Higher spec memory.
- TUF is one of the higher-end graphics card models (though haven't seen m/any 4090 roundups).
- Higher-end SSD.
