Choices choices
13 Mar 2020
Hi.
A little advice would be much appreciated.
So, I have pretty much settled on the Noble chairs hero. However having dropped a lot of money on a pc set up and monitor, funds really are limited.
My choices are:-
Hero BLACK Edition
Hero PU Red and Black and PU footstool.
I nearly pulled the trigger on a red and black last week, however foolishly waited and it went back up.
Cannot go for the Black Edition and footstool as my budget is very firm at 450 after all my other spending (Mrs will kill me...haha).
EDIT.... Someone suggested that the Noblechairs ICON may be a good choice too, however all the reviews and comments I am seeing says the Hero is probably a better chair... I'm 5ft 11 and do carry round a few spare pounds of weight
Thanks in advance
After lots of reading up and seeing the chairs at ICE Expo in London, I went with the Hero Black Edition as it is more breathable if used for long durations and I will be doing a lot of home working soon and I cannot fault it.
I am 6ft2 and 15.5st and it fits comfortably.
If you are not going to be using it for long durations at a time then the PU should be more than good enough.
Hope that helps a little
