Hi guys, I'm going to be building a rig with the following spec:
- ASRock Z68 Extreme4 Gen3
- Core i7-2600K
- Noctua NH-D14
- AMD Radeon HD 6850 (1 GiB)
- Cooler Master Elite 500 W
...and I need a case for it all. The CPU will be overclocked but I have the Noctua and also 3 very good 12 cm case fans so I don't think cooling will be an issue. I'm looking for something a bit smaller and cheaper than my Cooler Master CM690 since this rig will only have two HDDs and one ODD in it. I like PSU-at-the-bottom designs and great cable management would be ideal.
Any suggestions? Looking to spend £50 or less, unless there's a good reason to go higher. Is the Antec 300 still the de facto choice here?
- Core i7-2600K
- Noctua NH-D14
