Choosing a 7950
27 Jan 2008
Skip the Flex edition card unless you absolutely need extra DVI sockets. For the same price you'll get the cooler and quieter Vapor-X.
Hard to say which one you should go for. Quiet is of the highest importance to me, so I would be inclined to say Vapor-X. The VTX3D isn't awfully loud and the RMA is UK based. MSI longer warranty than both.
So it's the better card(vapor-x) vs cheap and easy RMA(VTX3D) vs Longer warranty(MSI).
I would just go with the MSI one. The coolers look amazing and perform well (at least I remember the Frozr II design did), and the extra warranty will be worth it. Don't skimp on the components, that extra £20 here and there can make the difference between components lasting an extra year or so.
