- 11 Aug 2007
Hi
I'm going to be buying a new case for my PC soon as my current one is a rubbish £15 no-brand thing. Basically I'm in two minds whether to go for a cheaper Cooler Master such as the Elite 330 or 335 or buy a more high-end/expensive case such as the Cooler Master Scout which I think looks awesome, but in the end the case just gets stuck under a desk really and doesn't affect performance in terms of how good the components are (apart from airflow/temps of components). I'm not really interested in the Antec 300 as apparently it has rubbish cable management and I don't like it much tbh.
Basically if I were to go for the cheaper case I could upgrade my CPU sooner, from a E2180 @ 3GHz to an E5200 or I could go for the more expensive case (the Scout or something else) but then it would be a while before I could upgrade the CPU.
Does anyone have any suggestions on what case to go for or if I should go for a cheaper/more expensive one?
Thanks for your help.
