Choosing a HTPC - Slightly above clueless
20 Nov 2007
Im after a HTPC to go with a LCD and 5.1 amp. I want it to be able to cope with the new formats blu-ray and play common video codecs (Xvid, DivX...etc).
Preferably an optical link to the amp and audio through HDMI to the LCD but a standard digital link would suffice.
Option 1 (173.86):
Intel Core 2 Duo E2200 "LGA775 Conroe" 2.20GHz (800FSB) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-190-IN&groupid=701&catid=6&subcat=793
£57.56
Gigabyte GA-73PVM-S2H GeForce 7100 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-098-GI&groupid=701&catid=5&subcat=326
£51.69
PowerColor ATI Radeon HD 2600 PRO SCS3 SILENT 256MB DDR2 HDTV/Dual DVI (PCI-Express) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=GX-084-PC&groupid=701&catid=56&subcat=938
£46.99
Option 2 (229.1):
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail
http://www.overclockers.co.uk/showproduct.php?prodid=CP-157-IN&groupid=701&catid=6&subcat=793
£123.36
Asus P5E-VM HDMI Intel G35 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-257-AS&groupid=701&catid=5&subcat=326
£105.74
Common (44.62):
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC&groupid=701&catid=8&subcat=
£27.01
Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=CD-096-SA&groupid=701&catid=10&subcat=951
£17.61
I will be changing this later when blu-ray/HD-DVD drives come down in price.
400GB Seagate SATA - Already have.
Silent PSU 350watt (it may struggle but ill see).
http://www.silverstonetek.com/products/p_photo.php?pno=gd02&area=usa
All this will be interfacing to a Sony 5.1 Amp and something like (yet to be purchased),
http://www.teleworldplc.com/model.asp?Detail=Yes&ModelID=343&Show=2
Maybe a different model, not sure yet.
Option 1 would be 218.48 and option 2 273.72. Ive put the cheaper processor in option 1 becuase of the GPU which maybe isnt justified? This is from looking but Im open to ANY system that does the job.
Many thanks in advance for help with choosing a system :)
Option 1 - why do you want a mobo with HDMI out when the graphics card will do the same job. :confused:
The E2200 will not be up to the task as regards blu-ray IMO , my E2180 didn't want to know & the E6600 dropped fames as well. I ended up getting a Q6600 GO in the end & it does the job. the E6750 or an E8200 may well fit the bill.
Thanks badbob, I have amended the list above - cheaper and passive (or looks to be :) ).
Oh, no reason for the onboard HDMI in option 1, simply because the motherboard is cheap, has 1333Mhz FSB and an optical audio out. In option 1 I will not be using the onboard HDMI for connection to the LCD. I was under the impression that having a separate card (e.g. ATI Radeon HD 2600) with hardware decoding made the need for a hefty processor redundant - is this incorrect? If so Id just get the all-in-one board solution of option 2.
Thanks for the input.
