- 24 Sep 2012
- edinburgh
So, I am choosing a new mousepad as I have the Roccat Sota and it doinh my nut if (too small and fraying edges).
So, I have been looking and I need one that serves dimensions of
If width <= 32cm then height can be >45cm
If width > 32cm then height must be <45cm
I have been looking at the Razor Large and also the extended (speed) versions which seem to be the correct spec in terms of size.
Is there any others that would be worth considering? Any reason to maybe try and go for a hard mat instead?
My mouse is a Logitech g600
