Choosing between 19" and 20" widescreen
Permabanned
30 Dec 2005
16,000ft
Ok, so what do I want?
I can pay ~140 all inc for the OcUK 19 incher, and hope I don't get a dead pixel, or spend 90 pounds more for a top quality 20 incher with no dead pixels. What do I do?!
spend the extra 90 find out that never mind how much the pay theres no way to avoid dead pixles then come on here and cry that you could have saved £90 :p
Now comes the mature part of my post if you can afford it go for the 20inch as i got a 20inch ws job the other day and its sexy as anything
OK, I'll shop around and get a 20". Theres a 3 or 4 possibilities I've seen around, so will get buying!
Cheers guys!
My wallet is going to track you all down and kill you though.
Just bought a 20" widescreen NEC here and it's the dogs proverbials!! Worth every penny imho.
^ £100 over budget though :)
I'd look at the Dell 2007WFP. It's better than the Viewsonic in every way except the colour banding which most will be able to put up with easily.
