Choosing between two Samsung models
Permabanned
4 Sep 2011
Durham
I understands these are not the greatest TV's in the world but for limited TV usage and some gaming, I have narrowed it down to two. Is one a lot better than the other or are they much of a muchness? One is a little more money but is it that much better?
SAMSUNG UE55RU7470UXXU 55" Smart 4K Ultra HD HDR LED TV with Bixby
SAMSUNG QE55Q60RATXXU 55" Smart 4K Ultra HD HDR QLED TV with Bixby
More the point I think, the 7404 which is the other one l I listed and not the q6, was the one I was going to pick up. Is it any good?
eh - you participated in the <£700 thread, which the Q6 'won', so £300/30% less than the current 1K xf90 price (£900 at its best price) ... but - you think Q6 is overpriced ?
I guess @oldestgregg read that thread too
The TV mentioned in this thread is the Q60 (currently £1k), not the Q6 (Sold out but widely available sub £700 before). The Q60 should priced the same as the Q6 hence it is way overpriced. Read before you post?
Its a low end TV from what I can tell, new release but reality is its a £500 TV. In addition to my post above and what @jpaul mentioned I found the Q6 in stock here http://www.cramptonandmoore.co.uk/samsung-qe55q6fn-55-inch-qled-uhd-4k-smart-tv-soloco.html if you dont want to push to the £1k sony this is a better buy than either you mentioned IMO
... you will be able to get £699 with 5years if you ring them up asap, based on the ebay reduction today. .... share the ebay commision with CM
edit: ;lol although I'd get a pan 55fx750 for £540
