Choosing boards for FX Overclocks.
28 Aug 2013
Looking at a FX 6350 for a cheap build, what are the board requirements for an overclock, am I basically looking for a board with phase rating 8+2?. The GA-970A-UD3 is the cheapest Asus/Gigabyte board that is higher than phase 6+2 (only 970 board I can find with 8+2 ive come across) . I do not require SLI or features of the 990x or 990fx, so am I missing anything, will this board be ok for a reasonable OC.
That board is ok. The Asus 970 R2.0 EVO has a very good reputation for overclocking. If you get the 6350 you're almost at the price of the 8320!
get a 6300 it overvlock the same!!!
i would use the asus sabertooth 990fx
but if u are on a buget The Asus 970 R2.0 EVO is verry good my son has one
I've seen people get their 8320s even to 4.5GHz on the Asus 970 EVO board. Although it's 6+2 phase, it's very high quality.
The 6300 and 6350 are identical except for the stock clock. There's no guarantee you'll get a higher clock. If you're happy to spend on the 6350, just get the 8320 instead. It'll do better in newer games.
Get the Giga board, strong clocker and you also have Gigas excellent support along with it.
