Choosing GPU for FX 6350
25 Aug 2016
Hi!
I want to change my old GPU HD 6950.
My system:
AMD FX 6350 (4.2 Ghz)
Zalman CNPS10X Optima
ASRock 970 Extreame 4
12GB DDRIII Kingston
HIS 6950 IceQ X Turbo 2GB
SeaSonic 650HT
Zalman Z9 plus
Philips 232E - 1920x1080
Budget $200 - $250
Games: NFS 2016, Dying Light, GTA V, BF4
12gb is a funny amount of ram. is that 3 x 4gb sticks?
Probs looking at a 4gb RX 470 or 480 assuming $ + vat = £.
I have a problem with one slot.
thanks for the recommendation.
and my processor is not bottle neck for gtx1060?
I wanted to buy rx470, but I was told that my processor is weak for her.
if your cpu is to week for a 470 then it would be even worse with a 1060, tbh I think rx470 will be fine if that's what you want to buy
Sets of two is ideal to make use of dual channel. You'd probably be better off with 8g in the correct working slots.
The processor will bottleneck in certain games / situations but you's still see a big improvement over the old 6950. Dx12 for a start and up to date drivers.
It will be fine, not ideal, but the upgrade will still be noticeable. I would 100% do it.
