Choosing the right Corsair AIO
8 Jul 2009
Derbyshire
Hi all, not been here in a very long time due to having a family, so yes the PC stuff was put on hold
Getting back into it though and I am after some advise on a new AIO, I am after a x3 fan 360mm one in white. I think I have knuckled it down too,
Corsair Hydro Series iCUE H150i ELITE LCD XT White
or
Corsair iCUE LINK TITAN 360 RX LCD RGB White
I like the design and the fact that I can customise the LCD screen. The issue is which one to go for as they look very similar? Any help or advise is welcome, I am also open to personal experience with these.
I currently have an old corsair AIO which has been brilliant over the years and a Fractal Design define 7 case.
Upgrades in the future
RGB RAM
white cabling
new corsair RGB fans
Maybe the upgrade to a AM5 setup.
I have the Corsair Titan 360mm LCD. First one blew up on install, no idea why but looking inside the the icue/link hub that comes with it, it has blown a voltage regulator and because it was daisy chained with all the other fans I think it's taken out all the other RX120 fans on the system (new Corsair 3500X case) but need to confirm.
Replacement unit is working fine, looks great and is extremely quiet so far, I like that there is a 0rpm mode on the fans. It's only really worth getting the icue stuff if you're happy shelling out for all the Corsair icue fans (and they're not cheap!).
If you can find one (and there happens to be a 'new / corsair re-conditioned one' on another very popular uk based retailer site - get the Corsair H150i iCue (not elite) as it comes with the much better QX120 fans. They seem to have discontinued or at least its a lot more difficult to find this model - which is what I run and I don't know why! *edit* Seems to be available direct from Corsair though!
