Christmas Weekend Stocking filler Deals 4 - Fan Controllers and Heatsinks!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Round 4 of the Christmas stocking fillers is now going live!
We have a selection of Fan Controllers and Heatsinks/CPU Coolers to tickle your fancy over the festive period! :)
AeroCool Touch 1000 4-Channel LCD Touch Panel Fan Controller @ £24.98 inc VAT
AeroCool are well know for producing some of the best fan controllers around and the Touch 1000 helps to confirm this. Like its big brother, the Touch 2000, it offers the ability to control up to four fans via a well thought out LCD touch panel display which shows the RPM and temperature for the selected fan/probe. But unlike the Touch 2000 that requires two 5.25" drive bays the Touch 1000 has all this functionality crammed into just one 5.25" drive bay.
- Stylish hair brushed aluminium front panel with diamond cutting
- Innovative Touch LCD technology
- Monitors and controls four fans and displays temperatures
- Overheating alarm temperature warning
- Lock function provided to prevent careless miss-touch
- Dimension: 149.5 (W) x 42.5 (H) x 70(D) mm
- LCD viewable area: 118 (W) x 25 (H) mm
- Connectors: 4 x 3-pin connectors / 4 x heat sensors
- Material: Brushed aluminium front bezel w/ steel bracket
- Max wattage per fan channel: 6W
Was £28.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
AeroCool Touch 2000 4-Channel LCD Touch Panel Fan Controller @ £38.99 inc VAT
AeroCool are well known for producing some of the best fan controllers around and the Touch 2000 helps to confirm this. It offers the ability to control up to four fans via a well thought out LCD touch panel display which shows the RPM of each installed fan. It also shows temperature readings of the four supplied temperature probes. These probes are to be placed next to or on critical components like the CPU and GPU heatsinks as well as items like hard drives and any other component that requires to be monitored. And if that was not enough the Touch 2000 also adds two USB ports, an eSATA port and audio ports for your convenience.
- Innovative Touch sensitive LCD panel
- Monitors and controls four sets of temperature and fan speed
- LCD backlight on/off
- 1 x e-SATA , 2 x USB , mic and headphone
- Dimension: 149.5 (W) x85 (H) x 70(D) mm
- LCD viewable area: 115 (W) x 57 (H) mm
Was £41.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Akasa AK FC-06BK Fan Controller Junior - Black @ £8.99 inc VAT
Akasa 3.5" Fan controller is more discreet than your standard fan controller, but still has an impressive specification.
- Black finish
- Speed control for 3 fans
- Aluminum panel and side rails
- 2 USB 2.0 ports
- Compact design for 3.5" bay
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa FC.TRIO 3 Channel Fan Controller - AK-FC-07BK @ £26.99 inc VAT
The FC.TRIO has a brushed aluminium panel and gives you control of three fans using temperature monitoring. Designed to accommodate three 30W fans with speed control down to Zero RPM. The VFD display has an off sleep mode.
- Brushed aluminum panel
- 3 control channels with temperature monitoring and alarm
- 30W available for each fan control channel
- Fan speed control to zero RPM
- High quality VFD display
- Display off sleep mode
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Scythe Kaze-Master 5.25" Fan Controller - Black @ £29.99 inc VAT
Kaze Master is able to control and monitor up to 4 fans, and 4 temperature monitor independently. These figures are displayed on VF-Display. To safely monitor and run your system, Kaze Master comes with the alarm feature to inform the user in case of fan malfunction. Also if the temperature goes above 75°C (165F), or in case of the temperature sensor failure, VF-Display will blink the number "0" or "0.0" and trigger the alarm sound. The alarm sound disturbs you? You can even shut down the alarm sound by a simple jumper setting! Both Celsius and Fahrenheit unit can be displayed by a simple jumper setting! By turning the knob to counter-clockwise all the way, the fan can be stopped. You can control fans between 3.7V – 12V to meet your needs for system requirement. By setting the voltage to the lowest level can silence your PC or turn it up to the highest to get the maximum cooling performance.
- 148.5 x 42.5 x 63 mm (WxHxD)
- DC Input: 5V or 12V (From PC Power Supply)
- Fan Adjustment Range: 3.7V (±10%) ~ 12V (±10%)
Fan Channel: 4
- 1A per channel
Fan Speed Range: 0 ~ 7500rpm (Display Range: 30rpm Incremental)
- Temperature Module Channel: 4
- Temperature Range: 0 ~ 100°C / 32 ~ 199.9°F
- Measurement Frequency: Every 2 Seconds
Was £34.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Zalman ZM-MFC1 Plus Multi Fan Controller - Black @ £21.98 inc VAT
Zalman’s ZM-MFC1 Plus is a simple fan controller which supports up to six 3-Pin fans. This provides the user with total control of the installed fans. Each channel is capable of altering the supplied voltage from 5V to 11V, with 5V able to quieten even the loudest of fans. The brushed aluminium finish and the LEDs, which increase/decrease in brightness depending on fan speed, give the ZM-MFC1 Plus a feel of elegance and quality that would not look out of place in any system.
- Channels: 6
- RPM Sensing: Active RPM Sensing (All 6 Channels)
- Maximum Power: 7.0W/Channel
- Input Voltage: 12VDC
- Output Voltage: 5VDC - 11VDC
Was £26.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366/LGA2011) @ £24.98 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.<br>
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.<br>
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.<br><br>
- Compatible with Intel and AMD systems<br>
- Three 8mm copper direct-contact heatpipes<br>
- Aluminum fins<br>
- Low-noise, low-vibration 120mm fan mounted on rubber studs<br>
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want<br>
- Air flow: 50 - 61 CFM<br>
- Noise level: 26 - 31.5 dBA<br>
- Two-year warranty<br>
Was £29.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £22.99 inc VAT
The tower CPU Cooler “Tranquillo” uses 4 power heat pipes and a special heat pipe constellation to achieve best heat transfer from CPU core to the aluminium fins in its class. After precise software simulation and calculation during the development stage a unique heat sink shape was created to lower air flow resistance as much as possible.
A silent 120mm fan with the intelligent GELID PWM (Pulse Width Module) control has been chosen to make this heat sink more valuable. The fan blades were optimised to guarantee high airflow while running silently. The intelligent GELID PWM curve keeps the fan silent when no necessary cooling is needed and accelerates the fan speed whenever additional cooling is needed. The multi-award winning high performance GC-2 thermal compound is already included in the package.
Additionally mounting clips for AMD 754/ 939/ 940/ AM2/ AM2+ and for Intel 775, 1366 and latest 1156 sockets as same as back plates for Intel LGA 775, Core i5 and Core i7 boards are all included.
- Socket Compatibility: 754 / 939 / 940 / AM2 / AM2+ / AM3 / LGA775 / LGA1155 / LGA1156 / LGA1366
- Dimensions: 74 x 125 x 153mm (L x W x H)
- Fan Speed: 750 - 1500 RPM
- Air Flow: 58 CFM
- Noise Level: 12-25.5 dBA
- Weight 645g
- 5 Year Warranty
Was £26.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
Asus Axe Square Limited Edition Gold CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £14.99 inc VAT
Axe Square AMAzing features a 120mm LED fan, five copper C-shaped heatpipes, a copper base and a large-scale heat dissipation surface area of up to 5500cm2 to facilitate highly efficient heat transfers in order to provide enthusiasts worldwide with the ultimate cooling experience.Ultra Silent at 16 dBA and Power Savings
Equipped with the PWM function, Axe Square AMAzing is able to adjust the fan speed according to the CPU’s temperature—providing users with the optimal operating environment at a mere 16 dBA, as well as helping to conserve energy and delivering CPU stability.
Amazing Gold-Aureate Design with Luxury Packing
Axe Square AMAzing is the latest model in the limited AMAzing series, and takes center stage with its stunning gold-aureate color; which juxtaposes with the black nickel-plated surfaces of unique axe-shaped design for the ultimate in aesthetic appeal. Moreover, this stunning Axe Square AMAzing comes in an extremely luxurious packaging with a limited-run identification card that ensures the fine quality of the amazing Series.
- Dimensions: 139 x 133 x 130 (W x H x D)
- Nickel plater for stunning looks
- Supplied with high quality thermal paste
- Noise Level: 16dBA
- Fan Speed: 1400 RPM
Was £19.99 Inc. VAT
Only £14.99 inc VAT.
ORDER NOW
IC Diamond 24-Carat Thermal Compound (4.8g) @ £12.98 inc VAT
IC Diamond out performs all other compounds in independent user testing amoung the popular brands tested, IC Diamond contains 92% pure syntheic Diamond. Purified synthetic diamond has a thermal conductivity of 2,000-2,500 W/mKL compared to 406-429 W/mK for pure silver. IC Diamond is electrically none-conductive and none-capacitive providing protection for electrical components when used.
IC Diamonds exceptional durability is due to its high bulk loading of micronized diamond particles. Each tube of IC Diamond contains over 92% micronized diamond and ais 94% fully loaded counting other miscellaneous particles. This highly loaded mix (90% + Bulk loading) is recommended by chip manufacturers to limit pump out due to thermal cycling.
IC Diamond is a stand out amonst all compounds by providing both high performance and long term reliability. Lightly loaded or creme type pastes initially provide some preformance, however the effect can be transitory, sometimes only lasterin a couple of weeks or months. You are safe in the knowledge that IC Diamond thermal conductivity lasts forever.
Based on Independent tests IC Diamond performs 2.77°C better than OCZ Freeze, 3.28°C better than Arctic Cooling MX-3, 3.38°C better than Arctic Silver 5 and 4.74°C better than the Intel generic paste.
- Each tube of IC Diamond Thermal grease contains 7 carats of micronized diamond with diamond particle loadings @ 94% by weight. Material loading above 90% is recommended as the best combination of rheological and thermal properties to minimize interface pump out due to thermal cycling.
- Superior bulk conductivity
- Excellent thermal impedance
- Tight particle distributions
- < 40 µ maximum particle diameter
- Silicone free
- Lower viscosity
- Greater stability
- Non capacitive or electrically conductive
Was £14.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Gotta say it, perfect timing for me, just as I needed to order a nice shiny new cooler, the one I want goes on offer..
*does happy dance*
Damn, I didn't realize fan controllers were this cheap. The Aerocool touch 2000 looks pretty sexy. Although I don't REALLY need one seeing as my nzxt phantom has a basic fan controller built in already. :D
