Chrome 32bit vs Chrome 64bit
18 May 2010
London
How many of you are using the 64bit version of Chrome?
I understand it drops support for 32bit Npapi plugins, but does flash still work?
It is out of beta right?
Is it time to make the switch, or do you think it's wiser just to continue using the 32bit version until Google drop support for Npapi plugins altogether and or make the 64bit version the default?
Don't think it is out of beta as yet for Windows anyway, not seen it being offered in the other versions and Windows versions will default to 32bit from memory.
Might need to check again and see if they are offering it at present.
I only learnt of this earlier today when I read an article that was talking about the current flash problems and it mentioned there was a 64bit version. Got it installed now, seems fine so far.
I never even knew that there was a 64bit version of Chrome for Windows. Only the 64bit one for Linux.
Exactly where do you get such a build? Is it beta/alpha, or on the stable branches?
I converted to Chrome ~2 years or so ago, but having just got BT Sport online, Silverlight does not run on whichever Chrome I have running in Windows 10.
I used 64 bit Chrome for a year now.
When I found there was 64 bit Chrome beta just over 12 months ago and I installed it and browsed it for a week, liked it more and I uninstalled 32 bit Chrome.
So it still in beta.
Javascript leaks so badly on Chrome you'll be glad of the extra memory. BTW it's a deliberate design decision in 64 bit Chrome that each process is limited to 4 GB.
Well I feel compelled to use Chrome as Firefox is unusable on my older Qx9650 PC. CPU spikes upwards of 60-70% on the simplest of websites.
Way smoother experience on Chrome.
Just, I've been using Firefox since 2007 so nothing quite feels like home.
