chrome 8 out...
5 Jun 2005
Southampton
mine had not updated, so going to 'tools and about' forced the update
Google has really been pushing versions of its Chrome browser out the window at an alarmingly fast pace. Since it's release (just two years ago), Google is now pushing it's eighth version of Chrome into user's eagerly waiting arms. According to Download Squad, Google has moved Chrome 8 (verison 8.0.552.215) to its stable release list. Don't be thrown off if you also see it in the Beta channel. For some reason, they're hosting it in both places.
Gone are the days where you had to download a browser plugin to view PDF files. Chrome 8 comes with its own PDF support baked right in. Also noted is Chrome 8's support for web apps. This is likely due to the Chrome Web Store that Google plans to launch in the near future. Sync, which is great for keeping your bookmarks uniform across your computers, has also been updated to support apps.
Besides over 800 bug fixes, there is also a new experimental feature called the Flags menu (accessed by typing about:flags in the address bar). It includes options for the following:
tabbed settings
side tabs
Instant Search
auto disabling of old plugins
cross-site scripting protection
GPU accelerated compositing
WebGL 3D canvas rendering
remoting
cloud print
There's no need to go and download the update if you're a current Chrome user. Google will automatically push it to you, as it always has. If you're not a Chrome user and you'd like to give it a go, visit Google Chrome's website and download a copy today.
8?
9.0.5xx here :p
It's great but the core extensions I require as a must have to make me switch are still not here yet (FireFTP, BBCODE Extra).
Baked in Flash and now PDF is a big security plus. Be sweet if they added QuickTime next although cant see it happening.
