Chrome Extension (JS/Jquery) Help needed
12 Feb 2013
East Mids
Currently working on a chrome extension that can look over the comment section of a Youtube page, running the script each time new comments are loaded in via AJAX.
Due to the new method Youtube loads in comments I have had to use DOM mutation observers as the usual event "DOMSubtreeModified" is now depreciated.
This is the previous, rather simple way of doing it.
Code:
$("#divID").bind("DOMSubtreeModified", function() {
    //run code here as the DOM has changed.
However I am now working with the following as the above code is depreciated. Only including the section that handles changes to the DOM to keep things simple.
The issue is I am getting the right number of console.log messages for the number of comments loaded, with more being added after the AJAX call however they are pointing to a null object.
Ideally I need the found results equal to the individual comments on any Youtube page, so they can be manipulated with JQuery.
console.log Messages in Chrome.
Code:
mutationHandler: script.js:12
[prevObject: e.fn.e.init[0], context: undefined, selector: "div", constructor: function, init: function…]
context: undefined
length: 0
selector: "div"
__proto__: Object[0]
 script.js:19
 script.js:19
 script.js:19
 script.js:19
 script.js:19
 script.js:19
 script.js:19
script.js
Code:
var targetNodes         = $("#watch-discussion");
var MutationObserver    = window.MutationObserver || window.WebKitMutationObserver;
var myObserver          = new MutationObserver (mutationHandler);
var obsConfig           = { childList: true, characterData: true, attributes: true, subtree: true };
// Add a target node
targetNodes.each ( function () {
    myObserver.observe (this, obsConfig);
function mutationHandler (mutationRecords) {
    console.info ("mutationHandler:");
    mutationRecords.forEach ( function (mutation) {
        console.log (mutation.type);
        if (typeof mutation.removedNodes == "object") {
            var jq = $(mutation.removedNodes);
            commentSelection = jq.find('div');
            console.log(commentSelection);
manifest.json (although most likely not needed.)
Code:
   "background": {
      "scripts": [ "jquery-1.7.2.min.js", "lib/typo/typo.js", "background.js"]
   "content_scripts": [ {
      "css": [ "skin/install.css" ],
      "js": [ "jquery-1.7.2.min.js", "lib/typo/typo.js", "script.js" ],
      "matches": [ "http://*/*", "https://*/*" ]
   "default_locale": "en_US",
   "manifest_version": 2,
   "name": "Test Application 1.0",
   "options_page": "options.html",
   "permissions": [ "http://*/*", "https://*/*", "tabs" ],
   "update_url": "https://clients2.google.com/service/update2/crx",
   "version": "0.1"
Any help would be great, been tinkering around with this for a good while now and at a loss on how to get it working. Thanks.
