Chrome paint advice please (not really case-related, lol!)
12 Mar 2003
USA
Hey,
I have an old Mathmos lava lamp that I managed to destroy by using Brasso on the chrome effect finish "legs". I'm assuming this was just spray on chrome effect paint rather than actual electro-plated chrome? What would be the best way to re-do the chrome finish? Looked into getting them electro-plated, but the minimum cost was about £75 which isn't really worth it!
Here's what they look like now vs. what they should look like...
Cheers,
Su
I would have thought chrome spray paint would be the cheapest solution, as to how good it would look I don't know as I've never used any.
What's a good brand of spray paint to use? And do I need to use primer or anything underneath? Don't want it to chip off really easily...
Cheers,
Su
they plastic or metal ?
loads of clear coat over the top should stop it flaking
i know the 'plastikote' chrome is ok but ive only used it on plastics
wow, i use brasso to clean my watch collection ( worth twice the amount of my car) and its never done that :confused:
this is some mess, but hey positive thoughts, positive actions ;)
have you thought it might be an opertunity to ditch the chrome look on the legs? (the paint is awful anyway)
how about a colour to match the oils in the lamp? orange or red maybe
or a cool blue? you could also go the easy route and get some blue 'hammered' hammerite spray paint, and have it done in 20 mins, looking good into the bargain.
Absolutely not :p firstly, the body and top are white, and the oils are clear with white bubbles, so anything other than chrome or white would look awful tbh!
I just want it to look the way it did before I butchered it :( brasso is totally safe (as you point out in your example) but I can only assume they used a really cheap and crappy chrome coating on the legs :mad:
Cheers,
Su
Hey,
Well I've been told they're probably made of ally and therefore not suitable for chrome electro-plating... but they can be anodised then polished to give a similar finish. Any ideas where I can get this done?
Cheers,
Su
