OcUK Staff
- 26 Nov 2014
- Stoke
That's right, the weather has sent me slightly insane, so I've opened my own precious metals shop, and here's a welcome offer for the whole of July: -
Buy any 550W/650W/750W/850W SuperFlower Leadex Platinum PSU in July for the SAME RRP as the equivalent Leadex Gold Units!
So you are getting a brand new SuperFlower Platinum PSU for what you'd normally pay for Gold AND the offer is open for the whole of July. BRB, some men in white coats are coming to take me away
SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - Black @ £71.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 550W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-550F14MP black (UK)
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Was £86.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 650W Fully Modular "80 Plus Platinum" Power Supply - Black @ £87.95 inc VAT
Features
Specifications
- Wattage: 650W
- Active PFC
- Partcode: SF-650F14MP black (UK)
Connectors
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Was £106.99 Inc. VAT
Only £87.95 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - Black @ £102.95 inc VAT
Features
Specifications
- Wattage: 750W
- Active PFC
- Partcode: SF-750F14MP Black
Connectors
- 2 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Was £117.95 Inc. VAT
Only £102.95 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 850W Fully Modular "80 Plus Platinum" Power Supply - Black @ £123.95 inc VAT
Features
Specifications
- Wattage: 850W
- Active PFC
- Partcode: SF-850F14MP Black
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Was £136.99 Inc. VAT
Only £123.95 inc VAT.
ORDER NOW
