- 19 Feb 2006
- West Mids
Something so simple in essence is proving to be a right pain for me to do.
Can someone reccomend a website that can generate or some software that can create for me the following.
I need to print off an A4 size piece of paper which on it has circles of a diameter of 2.8MM and the circles are 3MM apart in both width and length. So basicly graph paper but with circles not squares.
Idealy I need something that I can input the circle diameter, which will vary from 2.8MM through to 6MM and then vary the distance apart, but the lenght and width will always be an equal number.
Simple but beyond my means, so any help somebody could provide here would be great.
