Circular Polarizers
8 Mar 2006
York
Quick one. I'm aware that not all filters are created equal, but equally I don't want to spend silly money. I need a 77mm one for my 24-105 f4. Any recommendations?
Thanks
Dave
I've had some really good results with Gobe filters since switching to Sony (changed thread size on my lenses). Not bad if you're on a budget.
Thanks, I use Hoya HD uv filters at the moment, but Polarizers cost much more. I will push the budget out as much as I can justify.
Thanks
Dave
Marumi DHG Super’s have always got great reviews I’ve had a few over the years and can’t fault them. Not the cheapest of the most expensive but good bang for your buck!
I will be ordering a breakthrough filters one next month for the same lens, a mate uses their stuff and I was impressed with his results. It will be next month as I have their X100 system and 3 and 10 stop ND filters on order. The 25yr guarantee they offer was also impressive. It was about 115 quid, my only experience of filters previously was a cheapie off ebay and a hoya pro on my 58mm lens
In my experience, as with most camera equipment, the second hand market is always a good place to look. The Gobe filters and other budget models are fine however I picked up Tiffen and Hoya cpl's on eBay for around the same money.
