Hi all,
Looking to do some basic wood working to build a coffee table, build a flower bed using decking boards and a few other things.
Screwfix seems to suggest this one is decent for less than £60: http://www.screwfix.com/p/titan-ttb286csw-190mm-circular-saw-230v/60525
Anyone have any suggestions for others? Where is the best place to put the saw during use? I have a cheap B&D work bench so was thinking of putting it between the two bits of wood.
Thanks
EDIT: I'm getting confused between a Mitre saw and a Circular saw. Any recommendations on which is the most flexible / best for a beginner?
Thanks
I now made myself a large construction-timber workbench (~£40) that's heavy and with that it's side cutting, clamping to the bench (supporting over hang on the other side with a simple a-frame horse).
