Hi there,
I currently have the choice between 2 routers which I can use for testing purposes. These are the Cisco 857 or the Cisco 1720.
The Cisco 1720 currently has no ADSL WIC cards in the back, which would be useless for me anyway as my connection at home uses ADSL2+ technology (on BE).
I also have the option of a Cisco 857 which does support ADSL2+ pending firmware version which I will be checking soon.
Which one would be best to keep for learning purposes?
Any help appriciated from the Cisco guru's
Thanks all
Thanks all
