Hi all,
as a learning exercise I've been having a play with an old Cisco 1801 router, I have a little test setup at home and the plan is to put it behind a Cisco pix 501 and have a play with Vlans from a Cisco 2950 switch and some test domains.
So, before even attempting to do that I wanted to make sure that I could get something working. The current setup is like this:
netgear router -- 1801 router -- laptop on a static ip
192.168.1.1 -- 192.168.1.100 - 192.168.2.101 -- 192.168.2.102
Using this config below and natting, the laptop can ping the netgear router (192.168.1.1) and access the internet.
Router#show run
Building configuration...
Current configuration : 1250 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
ip name-server 192.168.1.1
multilink bundle-name authenticated
vtp mode transparent
archive
log config
hidekeys
vlan 2
interface FastEthernet0
ip address 192.168.1.100 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
ip address 192.168.2.101 255.255.255.0
ip nat inside
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0 overload
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
I don't want to be natting as the Pix will do this so I'm attempting to set it up like the tutorial in this link.
http://www.parkansky.com/tutorials/dmz.htm
For the life of me I can't get it working, I've all removed the natting bits on the inside/outside and the access lists above.
From the laptop 192.168.2.102 i can ping the vlan1 address 192.168.2.101 and fa0 192.168.1.100 but not the gateway of 192.168.1.1
I'm thinking that I need access-lists and i've tried lots
access-list 10 permit 192.168.2.0 0.0.0.255
access-list 10 permit any
And other various attempts on both interfaces in and out and I'm getting nothing, I have a feeling I'm missing something daft and it's doing my nut in now
Anyone got any ideas what's missing?
Router#show run
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
archive
log config
hidekeys
vlan 2
ip nat outside
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
shutdown
interface Vlan1
ip nat inside
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
