Hi guys, I'm a complete Cisco newb, and need some help if you'd be so kind! I've got an internal ESET server that I need to allow an external cloud hosted Labtech server to connect directly to it along with endpoint agents, the ports this communicate on are TCP 2222 and 2223. So ideally I need a static route that says all traffic on ports 2222 and 2223 be directed to the internal IP of the ESET server.
From looking at an old ASA5510 I've used before, we had something similar configured, and so I've taken lines from that and modified, if I add the following, do you think it'll work?:
permit tcp any any eq 2222
permit tcp any any eq 2223
static (inside,outside) tcp ext_IP_of_Router 2222 internal_ESET_IP 2222 netmask 255.255.255.255 tcp 512 256
static (inside,outside) tcp ext_IP_of_Router 2223 internal_ESET_IP 2223 netmask 255.255.255.255 tcp 512 256
If I'm on the right track... how do I go and add then go and add this to the running config?
Thanks guys
Thanks guys
