As the thread titile really.
I am new to Cisco and Im playing with my 857w. Scenario is as follows:
1. All hosts can ping the router.
2. All hosts can access internet
3. Wired hosts can ping wired hosts
4. Wired hosts can ping wireless hosts.
The problem I have is:
5. Wireless hosts can not ping wireless hosts.
Can anyone suggest what is wrong bearing in mind I am learning as I go !
Thanks for looking !!
Config is as follows:
Building configuration...
Current configuration : 6299 bytes
! Last configuration change at 23:20:27 PCTime Wed Aug 23 2006 by admin
! NVRAM config last updated at 23:20:27 PCTime Wed Aug 23 2006 by admin
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco857w
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5
username admin privilege 15 secret 5
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ip subnet-zero
no ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.9
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 10.10.10.1 212.23.3.100
default-router 10.10.10.1
lease 8
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name home.lan
ip name-server 10.10.10.1
ip name-server 212.23.3.100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
bridge irb
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Dot11Radio0
no ip address
encryption mode ciphers wep128
ssid dab27cscc
vlan 1
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
bridge-group 1
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect DEFAULT100 out
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 7
ppp pap sent-username
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 10.10.10.0 0.0.0.255
access-list 2 deny any
access-list 100 remark auto-generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit udp host 10.10.10.1 eq domain any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto-generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 212.23.3.100 eq domain any
access-list 101 permit udp host 10.10.10.1 eq domain any
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
access-list 102 remark VTY Access-class list
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 102 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login authentication local_authen
no modem enable
transport preferred all
transport output telnet
line aux 0
line vty 0 4
access-class 102 in
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
version 12.3
no service pad
hostname cisco857w
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
ip subnet-zero
no ip source-route
import all
lease 8
ip cef
no ip bootp server
ip ssh time-out 60
bridge irb
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/38
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
ssid dab27cscc
vlan 1
authentication open
station-role root
no cdp enable
bridge-group 1
no cdp enable
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname
ppp chap password 7
interface BVI1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip classless
ip http server
no cdp run
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
access-class 102 in
end
