Triad2000 said:I guess there is a 'fixed' copy?
Is it worth shelling the extra pounds on a cisco, or is it just a name thing?
Would you go for that model?
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Triad2000 said:The main difference seems to be the 107 has 12mb flash memory (is that used to store the firewall rules? Is 12mb a small amount?) and no VPN support.
mike1210 said:where did you get the firmware upgrade from, I havent had any problems with mine but just curious if there is a newer firmware out there![]()
mike1210 said:Toilen
