Cisco bods - STP issue
18 Oct 2002
Cisco 4506 x 2
Rapid PVST
12.2(18)
Problem: Spanning tree re-converges (fully 60 seconds) and causes switch-wide outage whenever a client turns off/on.
So I assume bpdu were being flooded when forwarding port went to down.
Tried portfast, bpduguard, bpdufilter. Still the same. The instant a host goes offline, spanning tree re-converges for that single vlan. I can unplug other hosts from other vlans fine.
This only happens on the switch that is NOT the rootbridge. If I swap the roots it happens on the other one.
I understand why the outage during STP re-converge, but a host cycle should not cause STP re-convergence, definably not on a portfast port.
Next steps are software upgrade (nightmare, client has no hardware maintenance), but it was working fine 3 weeks ago. No major changes noted.
This is doing my head in :D
Any suggestions?
how many devices are in this vlan? have you tried creating a new vlan and putting these devices in here and going from there?
