- 28 Oct 2002
- SE London
I'm trying to setup OVPN on my network, but my Cisco is being a bit of a *****, it's not opening up and/or forwarding on ports 443 and 1194 onto my server, here's my access-list and nat config lines:
If it helps any, it's a Cisco 1801, my configurational knowledge of Cisco's is limited to switches and, and making VPN pools.
Code:
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source static tcp 10.10.10.13 443 interface FastEthernet0 443
ip nat inside source static udp 10.10.10.13 1194 interface FastEthernet0 1194
ip nat inside source static tcp 10.10.10.13 8080 interface FastEthernet0 8080
ip nat inside source static tcp 10.10.10.13 80 interface FastEthernet0 80
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 remark INSIDE_IF=BVI1
access-list 1 permit 10.10.0.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 10.10.0.0 0.0.0.255
access-list 2 deny any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 permit udp host 8.8.4.4 eq domain any
access-list 101 permit udp host 8.8.8.8 eq domain any
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 deny ip 10.10.10.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip any any
access-list 101 permit udp any any eq 1194
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 8080
access-list 101 permit tcp any any eq www
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any any eq ntp
access-list 101 permit tcp any any eq 13680 log
access-list 101 permit tcp any any eq 8000
access-list 101 permit udp any any eq 55567
access-list 101 permit tcp any any eq 443 log
access-list 101 permit tcp any any eq 55567
access-list 101 permit tcp any any eq 54222
access-list 101 permit tcp any any eq 3074
access-list 101 permit udp any any eq 3074
access-list 101 permit udp any any eq 88
access-list 101 permit ip host 216.66.80.26 any
access-list 101 deny ip 10.10.0.0 0.0.0.255 any
access-list 101 deny ip 10.10.0.0 0.0.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 102 remark VTY Access-class list
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip 10.10.0.0 0.0.0.255 any
access-list 102 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
