Hi,
I have a CISCO 857 (running the 124-15.T5 IOS) and get an "Invalid input detected" as the following is present in the config: "no ip dhcp use vrf connected". This command gets added automatically when you define you wish to use DHCP within the config.
If I run "ip dhcp use" on the command line "vrf" isn't an option. I just have 'class'.
Do I need to worry about this error? DHCP seems to work OK.
I've tried rolling back to older IOS's and no joy, and also I receive more "Invalid input detected" on other config lines...
