Hi Guys
I've just invested in my first Cisco lab and it came with a 2509 Access Server. I want to configure this so I can use the 2509 as a gateway for my lab. However, being a noob, I'm a bit stuck!
From what I gather, it's all setup correctly, I have an Ethernet transceiver attached to the AUI interface which goes to my LAN and I have an Octopus Cable connected to the SCSI interface which connects to the routers and switches.
I've run through the initial configuration wizard and I did manage to get the AUI Ethernet interface working, however I can't fathom how I configure the asynchronous interfaces so that I can access the other routers and switches via this box?
Any help / advice / guidance greatly appreciated!
Thanks
Martin
Thanks
Martin
