Cisco Port-Security
5 Oct 2004
I'm having some trouble with my port-security config on a 2960
mac-address security is enabled on all the ports, the problem is that devices connected on the same switch cannot ping each other, ports 1 & 2 in this case
If I disable port security it starts working, also devices on this switch can access resources on the another switch that is connected to it
This is my port-sec config on the interfaces, I'm sure I'm missing something stupid but don't know what
Code:
interface GigabitEthernet0/1
 switchport mode access
 switchport protected
 switchport port-security
 switchport port-security violation restrict
 switchport port-security mac-address xxxx.xxxx.xxxx vlan access
interface GigabitEthernet0/2
that will be it, I turned on switchport protected as it was advised in the cisco article I read, probably should have paid more attention to what it actually did!
