I've started building my cisco lab but get the same issue on two 2620 routers that came from different sources. The built in ethernet and the WIC's I installed do not show up in IOS. Its onlt when I do a reload I see an error related to the ethernet port.
cisco 2600 (MPC860) processor (revision 0x200) with 53248K/12288K bytes of memory.
Processor board ID JAD05041C6L (2823619291)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
interface FastEthernet0/0
% Invalid input detected at '^' marker.
no ip address
% Incomplete command.
duplex auto
speed auto
Press RETURN to get started!
00:00:04: %LINK-4-NOMAC: A random default MAC address of 0000.0c84.02db has
been chosen. Ensure that this address is unique, or specify MAC
addresses for commands (such as 'novell routing') that allow the
use of this address as a default.
00:00:07: %SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly understood
Anyone got any idea how I fix this?
Thanks,
Paul
Bridging software.
no ip address
duplex auto
speed auto
Thanks,
Paul
aka ROMmon.
