cisco router reset?
28 Jul 2003
South Wales
How do i reset a cisco router to the manufacturers defaults?
i'm on cisco.com but i can't find out what the command is.
I've got a 3660, 1751 and a 1750 to reset.
any ideas?
any ideas?
If you have the passwords try erasing the startup-config and reloading the router. Off the top of my head (in enable mode) erase flash startup-config. Then issue a reload command.
If you don't have the passwords try google'ing for "cisco router password recovery" there's usualy a good link for this on the first page of results.
startup-config is in nvram, not flash.
delete nvram:startup-config will do the trick.
found an article on how to do it now.
Used the 'erase write' command. did a reload and i then get taken into the initial setup process when it comes back up.
thanks for the quick replies.
