Cisco switch console connection
28 Jul 2003
South Wales
Is there any way of getting onto a cisco switch without using the console cable?
my current machine doesn't have a serial port and i need to get the software revision from the switch.
Reality Bites said:
Secure Shell
Don't you need the IP address for a telnet session though? can't remember if i've configured it with an IP
Yep, you'll need the IP address for telnet, ssh, http or https access. Without the IP address you're stuck with using the console port.
Reality Bites said:
oh well....will have to get a lappy from somewhere with a serial port.
Trying to get as much info as poss about it so i can flea bay it....need the funds. :(
What model is it?
