Cisco Switches
Man of Honour
17 Nov 2003
Southampton, UK
I'm after a 24 port 100mbps Cisco switch with gigabit fibre uplinks. Basically a Cisco 2950 with an uplink.
What models can you suggest?
Burnsy
Burnsy
2950 24 port should do it, they come with 2 GBIC interfaces which allows you to connect fibre GBIC converters, They cost around £800
Quite a few for sale on "The auction site"
I've finally found a number for Cisco and phoned them up (thats not easy to find). I need 15 2950-24 and 5 2950SX-24. Unfortunetly this is for work and we need the gaurentee etc, but I've had a quote for about 8.5K.
Burnsy
didn't think the 2950 had gigabit uplinks - mine at home doesn't. The 3500 under my desk is a 48-port but does have dual gigabit fibre uplinks....
You're right - it doesn't have gig uplink ports.
You need to look at the 2950-24EL if you want GBIC's or 2950-24T if you want RJ45 uplinks.
lol oh well,
we've got nearly 300 2950s at work and they've all got Gbics, I dunno the actual model number but I don't order them. 2924G I belive is the one you want.
Part number/description:
WS-C2950G-24-EI = 24 10/100 ports + two 1000BASE-X ports
WS-C2950T-24 = 24 10/100 ports + two 1000BASE-T ports
WS-C2950C-24 = 24 10/100 ports + two 100BASE-FX ports
If the uplinks are just between cabinets then the WS-C2950T-24 is the one you are after - however the top option gives you the flexibility of using GBICs if required.
GBIC part numbers are:
WS-G5483= 1000-Base T GBIC
WS-G5486= 1000-Base LX GBIC (long-haul, singlemode)
WS-G5484= 1000-Base SX GBIC (short-haul, Multimode)
Right, I need one more switch. This needs to have at least 16 gigabit copper ports but at least 24 would be preferable. It also needs minimum 6 fibre ports but 8 would be preberable.
We currently have SC type fibre patch cables, but the 2950SX has MTRJ fibre connectors, so i'm not sure if they do SC ports outside of a GBIC. And it needs to be short haul, multimode.
Any ideas on a model?
Thanks
Burnsy
Thanks
Burnsy
Don;t think you can fit all the above into a single Cisco model, with 16 gigabit copper ports and 8 ports cable of SC fibre, Gbic or not, there isn't a model which does all of that.
For a switch which does 16 port gigabit copper, the new 2960s are pretty good, WS-C2960G-24TC-L is the cheapest gigabit switch they do.
For 8 fibre connections you'd need something like a 3550-12G which would give you 10 Gbic interfaces and 2 copper interfaces, again expensive.
If it was me, i'd get the 2960 with 24 gigabit ports, then buy 8 fibre line drivers, like a Lancast box or something. plug those into 8 ports on the 2960 to convert them to fibre, and your away.
As V-spec says, ther is nothing in the Cisco range that will cover that lot (unless you fancy a 6500 :D ) - the 3560-24G is probably the closest with 24 copper and 4 SFF (small form factor) GBIC slots. The 3550-12G that V-Spec mentioned is about to be EOL as well (think it's the end of March) so if you go down that route be quick.
Ok, What if I were to split it and have a stanard Gigabit copper switch (easy enough to find) and a dedicated Fibre switch. For the fibre switch I'd need at least 8 ports with MT-RJ connectors. Any switch that could do this without GBICs, as they're extra cost? I'm finding it hard to get a switch without a ridiculous number of ports left over and a pricetag that would make babies cry.
Question about the SFF GBIC slots, do they have two ports per module as standard large GBICs(in MTRJ format)?
Burnsy
Edit: I've got someone from Cisco presales support calling monday so hopefully that'll clarify everything if I'm not crystal clear by then.
Burnsy
3560s are very expensive, also, the SFP connections on a 3560 mean you need different patch cables then normal SC for a Gbic, because the connections are tiny.
If It was me, and I was trying to save money i'd buy a 2960 and get a load of fibre transceivers for the fibre.
